Shelly wave shutter, electric connection help
hi every one,
I currently have the following connection:
3 wires coming out of the motor side: 1 brown, 1 yellow, and 1 blue.
Each wire is connected to a wire of the same color going into the electrical panel (connection made with a terminal each to connect them between wires of the same color).
Then everything is controlled by a wireless switch made by the same brand as the motor.the brand is called Simu
Do you have any idea of ​​the best connection for the Shelly Wave Shutter module? Thank you.
I should point out that the radio frequency between the switch and the motor is in BHZ format.
Hi Moun_Mar, … I do not have the Simu tubular motor nore the roller shutter.
The BHz radio protocols are proprietary, no direct communication with Homey.
Since the power supply for Simu seems to be 230 V/50 Hz the control can be taken over by Homey with another protocol.
I have more or less the same situation with another brand, for me the Shelly Wave Shutter could do the job, so I use two switches, one for up , one for down, a Flow with timers handle the on/off status.
For the colors it does not matter as soon as you know the color of the common, since you can control the Simu with the proprietary remote it should be possible to determine which color is for what with a simple multimeter.
Thank you for your reply and sorry for the delay.
This means that apart from putting two Shellys per roller shutter, I have no other solutions for handling with Homey? Maybe something other than Shelly controller ?
