Shelly on matter
Im having the Shelly v3.63.2 app installed.
And I have several devices mapped.
Two out of them are Shelly 2PM Gen4, using matter
The problem im facing with both of them, is that they from time to time get to a stage “Not avalible” in Homey. They seems to loose connection, and does connect back them selves.
Then I must reboot them from the Shelly control center, and then use the Repair function in Homey. Add them again with the matter code.
Someone else have the same or similar problem?
Regards
I recommend you to use the device over regular LAN (with the Shelly Control app for Homey) instead of Matter. Matter is a very unstable and experimental standard and I wouldn’t recommend it if you expect reliability
