Shelly 1 PM mini gen 4 status synced niet met homey
Hi All,
i have 2 Shelly 1 pm mini gen4 connected over matter to Homey, and i can switch on/off the lights with the wall switch an through homey.
there is only on problem, when i switch on or off with the wall switch the status is not synced with homey.
so when i switch on with the wall switch the status in homey remains on and the same goes for switching off.
anyone have that experience as well? and what can i do about this?
I could not connect with the Homey app. I had to use the option “Use Android”. That worked fine.
I thought that was the reason that the status is not synced when the fysical lightswitch is used.
You can also use the regular API connection instead of Matter, API is often more stable
