Shadow on/off image
I have three Sonoff ZBMINIR2 smart switches that are identical. They are installed on three identical lights. Yet one has a shadow on/off image. Any thoughts on the cause? Why is the shadow only on one and not all/none? Many thanks.
Because the lamp has a different color I guess. Look at what colors are shown when you switch on the lamps.
@gary.osullivan Make sure to set the connected device to light in the settings of the devices.
Since the ZBMINI is a just a relay switch, the Homey app doesn’t know what’s connected to it until you declare that in the settings.
Once it knows that a light is connected, it will show the on/off light indicator.
Thanks both.
They are all the same bulbs/lamps/colour.
All three were set as ‘light’. However, only when I toggled from light to other and back again, did it update the two lights.
Thanks again.
