SG Smart app
Hello :smile:
i have some SG smart spots in my home, will the SG smart app come to Homey pro at some point? :smile:
You can ask it here if someone can or make an app for it if it not allready there.
https://community.homey.app/t/homey-pro-community-app-requests/2713
Also need for SG Smart app in Homey Pro 23. All SG Smart units are Bluetooth based, except for the Hub which is WiFi. Link to products, SG Armaturen | Products | SG Smart
me too. any news on the sg smart app?
+1 SG Smart :crossed_fingers:
Is this not possible? I have the SG smart at home, and its the only think stopping me to buy Homey pro… I have the SG smart in my Google Home. It it not possible to add the SG gateway to Homey pro?
Go to this Homey Pro Community App Requests - #322 by Kfk and like topic 108 with the sg smart app, so maybe there is a developer that can make it happen :grinning:
Just figured it out
-Install the ā€œhomekit controllerā€ app.
-Go to add device, you will then find the SG bride
-insert pin code that is on the underside of the SG bridge (along with the QR code)
You now have the bridge, and can add devices to rooms as normal.
-Add device
-HomeKit
-HomeKit IP
-select device and add to room.
I have managed to add all my SG smart devices to Homey using this method, but I cant control any of them. Any tips?
You can try to restart the app. I have to do that from time to time. I’m not suer if it’s the app or the bridge, but something freezes sometimes.
Hi
I have a problem with the controller. It freeze several times every day. Due you have this problem?
Brgs
Runar
Not several times a day, but several times a week maybe.
I have had none since I deactivated the timer schedules in the SG app a few days ago when I left for the holiday.
I have not found a way to make a flow that auto restarts the app when this occurs, but that could be an easy fix. Restart every hour might be another possibility if you have this problem that often.
I have 15 lights / sockets, and two switches. It would be interesting to know if more units make the problem appear more often, or if it it is a hub or app problem.
I dont think it possible to make a flow to restart the appšŸ˜®ā€šŸ’Ø
Have you see on the log file when the app is freeze?
Runar
I think you might have to use another trigger than when the app has crashed, but see my example under as a proof of concept.
I have not reviewed the log, so I’m not sure of the reason. I have not had any restarts since before christmas.
Hi
Where due you find this card?
My fault. Power user has to be enabled. Automatic restart apps when all devices get unavailable - #8 by Arie_J_Godschalk
Jeg fƄr to forskjellige meldinger;
Enten
Nye enheter er funnet
Cannot read properties of undefined (reading ā€˜update’)
Eller
Ingen nye enheter har blitt funnet.
Er det noen som har tips til Ć„ komme videre?
