Connecting SG Smart to Homey
Hi, can someone help me to connect my lighting system(SG smart) with homey? The system is Bluetooth based and currently gathered in app called SG Smart.
It doesn’t look like there’s a Homey app for that brand, in which case you won’t be able to connect them with Homey.
hello all homey,
I’m considering buying the new homey pro, but I would like to know first if there is a way to connect sg smart to homey, because I can’t find any information about it
Welcom Vmate,
If there is no app, the change is small that it is going to work.
See app store for products that work
Hello :smile:
i have some SG smart spots in my home, will the SG smart app come to Homey pro at some point? :smile:
You can ask it here if someone can or make an app for it if it not allready there.
https://community.homey.app/t/homey-pro-community-app-requests/2713
Did you find a soloution to this? I also have SG smart and would like to connect it to Homey
All the best
/Joakim
Also need for SG Smart app in Homey Pro 23. All SG Smart units are Bluetooth based, except for the Hub which is WiFi. Link to products, Products - SG Armaturen
me too. any news on the sg smart app?
+1 SG Smart :crossed_fingers:
Is this not possible? I have the SG smart at home, and its the only think stopping me to buy Homey pro… I have the SG smart in my Google Home. It it not possible to add the SG gateway to Homey pro?
Go to this [Requests] Homey Pro Community App Requests - #322 by Kfk and like topic 108 with the sg smart app, so maybe there is a developer that can make it happen :grinning_face:
If you have the SG Smart Gateway you can “homekit link” that via the Homey application “HomeKit Controller”. Everything working fine (so far).
Just figured it out
-Install the “homekit controller” app.
-Go to add device, you will then find the SG bride
-insert pin code that is on the underside of the SG bridge (along with the QR code)
You now have the bridge, and can add devices to rooms as normal.
-Add device
-HomeKit
-HomeKit IP
-select device and add to room.
I have managed to add all my SG smart devices to Homey using this method, but I cant control any of them. Any tips?
You can try to restart the app. I have to do that from time to time. I’m not suer if it’s the app or the bridge, but something freezes sometimes.
Hi
I have a problem with the controller. It freeze several times every day. Due you have this problem?
Brgs
Runar
Not several times a day, but several times a week maybe.
I have had none since I deactivated the timer schedules in the SG app a few days ago when I left for the holiday.
I have not found a way to make a flow that auto restarts the app when this occurs, but that could be an easy fix. Restart every hour might be another possibility if you have this problem that often.
I have 15 lights / sockets, and two switches. It would be interesting to know if more units make the problem appear more often, or if it it is a hub or app problem.
I dont think it possible to make a flow to restart the app​:face_exhaling:
Have you see on the log file when the app is freeze?
Runar
