Hello. I would like to be able to have a flow that invite me to give a température Numbers and then give this Number to Tado temperature node. I try when this flow is running then Logic Numerik variable - number but it didn’t work. Anny idea ?
You might be able to achieve this by:
Creating a variable for the temperature; This variable is used by your flow.
Put the variable on your Dashboard using the Logic widget:
Finally, include a shortcut to your flow on the same Dashboard, so you can start the flow from the dashboard.
You would then go to your dashboard, change the temperature value to your liking and start the flow via the shortcut on your dashboard.
