Hi everyone,
I’m running into an issue with IKEA Matter integration and I’m hoping someone has seen this before.
My setup
Homey Self-Hosted
Homey Bridge
IKEA DIRIGERA (firmware 2.901.5)
Matter version 1.0
3x IKEA KAJPLATS (Matter over Thread)
Important: Homey Self-Hosted + Bridge does not support Thread, so everything has to work via DIRIGERA as a Matter bridge
(Thread → DIRIGERA → Matter over WiFi → Homey).
The issue
When I add DIRIGERA to Homey using the Matter pairing code from the ikea app:
The bridge is added successfully
The Matter device appears in Homey
But no bridged endpoints (no lights) show up
I only see the root bridge device
All 3 KAJPLATS spots work perfectly in the IKEA app.
What I’ve already tried
Removed the Matter bridge from Homey
Power-cycled DIRIGERA (30+ seconds)
Waited a few minutes before pairing again
Still no bridged endpoints.
Important detail
At a colleague’s office, the exact same type of setup (Homey Self-Hosted + Bridge + DIRIGERA + IKEA lights) does work, and the bridged light endpoints do appear in Homey.
So it seems technically possible.
Any help from others running this setup would be greatly appreciated.
Thanks!
EDIT: After further testing I’ve gathered some additional information.
In Homey, when I open the DIRIGERA Matter device, I see:
Device types:
root_node, aggregator -
No
bridged_node -
No light endpoints
No child devices at all
So Homey clearly sees the bridge itself, but no bridged endpoints are being exposed.
Additional testing results
An old IKEA TRÅDFRI Remote Control does appear in Homey.
A IKEA STYRBAR does not appear.
My IKEA KAJPLATS (Matter over Thread) also does not appear.
Important:
Everything is connected only via Matter (I linked DIRIGERA to Homey using the Matter code). I am not using the IKEA Homey app integration.
What this seems to indicate
The Matter bridge pairing works.
The bridge itself is visible in Homey.
However, DIRIGERA is not exposing any bridged endpoints (or only exposing certain legacy devices).
Because I’m using Homey Self-Hosted + Homey Bridge (no Thread support), the KAJPLATS spots must be exposed via the DIRIGERA Matter bridge to be usable in Homey.
Right now, that does not seem to happen.
My main question
Does DIRIGERA expose native Matter-over-Thread devices (like KAJPLATS) as bridged endpoints over Matter?
Or is this currently a limitation of the DIRIGERA Matter bridge implementation?
