Searching for the right thermostate
Hello everybody,
I did not really find it via search, so I will address it here. Thank you in advance!
Technical basis:
New building in Germany
detached house
Approximately 10 thermostats necessary
Smart functions would be great
underfloor heating
Battery or connected to the electricity: I’m still unsure
For our new building I am looking for nice thermostats. Our electrician proposes TADO and HOMEMATIC. As far as I know and find, Homey supports TADO. Here, however, comes to me negatively that you probably have to pay subscription fees to TADO, if you use smart features … Is that the case even if Homey managed the “smart functions”? Homematic I think so far not supported by TADO (search on the thermostat page).
What would have liked so far is “ThermoSmart from Thermosmart B.V”. However, I find little technical information or a real purchase option. Seems to be very expensive too.
Visually, I find “https://www.athom.com/en/store/product/plugwise-anna-thermostat/” very interesting and also priced at 99 € / piece. Has anyone had experience with it? The technical data are unfortunately not very detailed (well, I’m also a layman) but I can not see if they send their signal via WiFi and need batteries or need to be powered by 12V or 230V. Do the Anna - Thermostats ONLY work with Tado or would they work on their own, if Homey should not exist in 5 years, etc …
I am really happy about your answers and experiences. Our electrician wants to get in touch as soon as possible … Thank you, Franz
PS: Please excuse me for posting this topic in the german forum paralell.
Your choice of thermostat is very dependend on your own wishes and what wishes are most important to you:
1 how important is heating function to you (and the wife ;-), will you rely on bluetooth or wifi(tado) or do you want the system to work even if your wifi is down (evohome and others)
2 do you want to control the valves on the radiotors too? (Tado, evohome, danfoss) Or just the thermostat itself? (Thermosmart, toon, plugwise)
3 do you want to control seperate zones? (Evohome) Or control all radiotors based on a thermostat in one room (living) (thermosmart, plugwise, toon, tado)
4 how much are you willing to spent… (evohome is really expensive)
5 do you want homey support available?
I use Tado and I’m very pleased with it. I did however get mine before they introduced the subscription for certain features. I find the Tado geolocation is the most reliable of everything I have tried, but if you don’t want to pay the subscription then you can use homey to set the temperature instead.
I use the Tado valves on all my radiators and I have a few thermostats in certain rooms for better control. I also have a Tado thermostat controlling my under floor heating in the kitchen.
I use sensors fitted to doors and windows that are connected to homey to lower the target temperature when one is open and set it back when it is closed.
So homey can do the control but the basic function still works when the network is down.
I hope that answers your questions about Tado.
@Adrian_Rockall - Am I right that I can use the valves without the tado bridge?
No, the Homey app talks to the Tado bridge via the internet., so still need the bridge.
Thanks for your feedback - but with a need of a bridge they’re useless for me.
Just to be sure before I ditch my Fibaro radiator valves… When there is no internet connection, will my Homey (flows) still be able to set the temperature of the Tado radiator valves of all the different rooms? Or is for every command that is send to the valves an internet connection needed?
TIA
An internet connection is required for Homey to communicate with Tado.
Tado will continue to work by itself without an internet connection but Homey can’t change or monitor it.
That sucks then :slight_smile: Not that I have an internet connection that if offline regularly but still.
Thanks for the info. Maybe I should look into the plugwise hardware, from what I’ve read they do do integrate with Homey even when no network connection is available.
You can use the Eurotronic Spririt Z-Wave thermostats (or any other z-wave thermostat with Homey app support). They are connected directly to Homey with z-wave without the need of other hardware/cloud services.
Yeah, but these are also FLiRS devices, and I assume they will give me the same problems the Fibaro FGT-001 are giving me.
Question about the Tado;
I read about the costs to use the geolocation feature and the open window feature. Is there a possibility to use homey for geolocation for your Tado? I don’t want to have a subscription.
Yes. You can change the temperature of the thermostats when Homey detects you leave and arrive. You can also use window and door sensors in Homey to detect an open window or door and change the temperature.
The only thing I would say is I find Tado geolocation is the best I’ve found and use that to control Homey.
Alright thanks for your information! But for geolocation on the new v3+ you have to pay 3 euro’s a month right?
I think that’s correct but because I got mine before they started charging I don’t have to pay. A perk of early adoption :blush:
Would I pay? Probably!!
