SDK3 and timezone from calendar events
As of SDK3, Athom has changed Homey to always work in UTC timezone… :man_facepalming:
I am trying to move my app IcalCalendar from SDK2 to SDK3, but this change in timezone behavior has made it quite problematic.
In SDK2 the calendars were read and start / end were correctly converted to date objects with correct timezone offset.
In SDK3 the calendars are read but start / end are converted to date objects with UTC, and are missing timezone offsets.
I can use moment with the timezone found in Homey (this.homey.clock.getTimezone()) to get the offsets back, however i don’t seem to have found the correct way to add the offsets to the date to get correct start / end.
Has anyone has any luck achieving this correctly?
The code is here if someone would like to take a look: calendar-homey/get-active-events.js at sdk3 · runely/calendar-homey · GitHub
Yes, just because Athom cannot handle timezones all developers have to suffer :grimacing:
I’m not sure I understand.
You can use moment-timezone to convert a UTC timestamp to a local one:
const moment = require('moment-timezone');
const d1 = new Date();
console.log('Date', d1.toString(), 'Offset', d1.getTimezoneOffset());
const d2 = moment.tz(d1, 'Europe/Amsterdam');
console.log('Date', d2.toString(), 'Offset', d2.utcOffset());
If that’s not what you need, what exactly is it you do need? The code you’re linking to contains too much context to understand the underlying issue you’re having :sweat_smile:
By the way, you can run the above code locally with Node.js, which saves some time with the whole make-a-minor-change-and-upload-your-entire-app cycle for Homey. To set the timezone to UTC, just like with SDKv3, you can use the TZ environment variable (at least on Linux and macOS):
$ env TZ=UTC node test.js
I was already using moment-timezone to convert the date to local, but hadn’t found the correct way to add the offset. With your suggestion to set my local TZ to UTC it helped quite a lot and sped up the process, so thank you!
