Apologies if this has been asked before but is there a good way to capture or screenshot my Homey flows? I know I can take just a simple screenshots from my Mac on the simpler ones but for some of my LARGER flows, it’s proving difficult to capture them.
The reason for this is to have an archive of my flows in the event that my SHS crashes and I need to rebuild the flows quickly.
Though it requires some more effort, the advantage of the PDF-method is that you can always see what flowcards and which variables/tags you had in your flow after the related device/app/variable has been removed from your Homey.
Keep in mind that after removing a device/app/variable, Homey replaces the related flowcards and tags with greyed out ‘unavailable’ message. It is then difficult to determine what the original flowcard/tag/variable was. This is also the case if you import a flow that contains flowcards of apps/devices that are not available anymore.
Further, If you want to keep multiple backup versions of your flows and maintain a recycle bin of deleted flows, make sure to check out the Flow Version History app by @smarthomesven.
