Running Advanced flow from iPad
Cant run advanced flow from my iPad. I have a Homey Pro.
Regards
Arne
What happens if you press the green “play” button for the flow?
Nothing happens. It says that the flow is correct but I a can not start it manually.
In that case your flow probably doesn’t have a Start button:
I am trying to make a flow that says if my Aqara temperature sensor is less than 18 degrees celsius than it starts my Daikin AC heating mode. I use Daikin AI.
Advanced flows can only be made using a webbrowser on dektop or laptop device. Not on ipads or other tablets.
I am doing it on my Macbook Air M1.
I am a beginner of doing advanced flows.
It doesn’t make sense to start such a flow manually, it should be started when the temperature drops below 18 degrees.
Correct.
I assume you mean ‘not in the Homey mobile app on iPad or other tablets’. You can of course, open the Homey web app on an iPad to access Advanced Flows. Though maintaining them on a tablet is ‘challanging’ to say the least :sweat_smile:.
If it’s only for testing purposes, you can right click the trigger card on your computer and select ‘Test from here’.
