Rounding Numbers
I want the numbers to be rounding to some decimalen.
See screenshot
The number is shownieuws with a lot of non significant decimals.
How can I limit it to 2 or 3 significant decimals?.
Can you show the complete flow? How are these numbers being calculated? Which variable or which app?
As an alternative to the above, if you also want to control the locale (e.g. using a comma as decimal separator, instead of a period), you might want to consider the ‘Format number as’-flowcard from the Better Logic Library app:
The example formats a number with 2 decimals and using the Dutch locale (comma for decimals; period for thousands).
Thanks
It works
And in general:
I miss documentation and examples of special commands like round(22/7,3)
Goto https://mathjs.org/ for these math.js commands. Most of these can be used with Homey.
