I’m guessing it’s a string, since it contains °, and you can’t call round on string. If you can create a homeyScript then what you need to do is parseFloat and then call ToFixed(1) on the result
It depens on the LocalAPI app I think. You insert a nuneric token and the app returns a JSON.
How is the JSON built? With numeric value or string value?
If the JSON contains a string element, then it’s converted from number ti string inside LocalAPI app.
I suggest to ask the app developer
I also tried to use the logic card to round a value.
Round a value like 1.23 gives 1 as result. So you can round like round(1.23×10)/10 to get 1.2
Problem: round(1x10)/10 gives 1 as result, not 1.0
I would say that’s why you get no zeros as decimal.
