Hi everyone,
I’m new here, so please tell me if I’m posting correctly or not.
I am trying to setup some dimmable overhead lighting in my kitchen, using a dimmer from the Robbshop branded Sunricher device line. As a test I connected 1 of the lights (Philips Gu10 dimmable) with the dimmer and tried to control it from the Robbshop Zigbee 3 wire dimmer app. Turning it on and off works fine, but when I use the dimmer function the voltage doesn’t go any lower than 200V and the light barely dims while the dimming percentage is set to 5%. Based on the specs I would expect it to be able to drop to 100V.
Have any of you used this device to dim GU10 spots and did it work in your case?
O well, try again tomorrow I suppose.
