New version published
Version: 0.2.7 Beta
- Added Chime functionality (Ring Keypad V1 and Ring Keypad V2)
- Added Flow cards to activate Siren manually (Ring Keypad V1 and Ring Keypad V2)
- Added Flow cards to activate Chime manually (Ring Keypad V1 and Ring Keypad V2)
- Added support for Contact Sensor V2
- Added support for Outdoor Contact Sensor
- Added preliminary support for Motion Sensor V2
If you have a Ring Doorbell connected to your Homey you can now use your Keypad as a Chime without the need of any flows! Please select the desired Chime sound in the devices settings.
If you don’t have a Ring Doorbell you can still use your Keypad(s) as a chime, just use the flowcard to play the sound you like!
This version also adds support for the Contact Sensor V2 and the Outdoor Contact sensor, unfortunately no correct images for inclusion yet, they will follow.
And lastly; preliminary support for the Motion Sensor V2. Unfortunately I don’t have this sensor so I can’t test if this works correctly. If you have such a sensor, please add it and report back if it works.
