Ring Gen 2 internal Camera no live view and not truning on lights
Hi
I have connect my internal ring camera via the app. by Danne de Kruyff
I do not get video previews with these camera. Door Bell and other type of ring cameras both give live view but not the Gen 2’s
Second i set a simple when motion detected and after sun set turn on hue light and some for off when motion not detected for 20 seconds. Both run and work in the test but niether work in real life.
Any help much appricatied
Thanks
Andy
You should report your issue to the app developer. The Ring app’s developer is Athom, so you should contact them here:
Hi i am using the community one
Thanks
Andy
In that case, you should report your issue here:
Hi
I am using the Ring Gen 2 camera Indoor Camera – Ring so should work i guess but the test works but not when i try to walk infront of camera nothing happens
Andy
Hi Andrew,
Please follow the link (blue colored text) on top of the topic preview @smarthomesven Sven shared here.
There’s a system in this forum :wink:
Next, the first posts of App Topics often provide for setup info, FAQ, and troubleshoot sections.
When post your question, the developer gets informed as well. In general devs do not scan the forum for app related questions :wink:
So, continuing posting in this topic won’t get you any further.
(Meant to help you on your way, not to judge.)
