[Request] Web interface
I have just released Dashboard Studio. It is more of a design tool that isn’t bound by rigid columns or grids, so you can build your own dashboard pixel-perfect. It supports layering elements, and almost every parameter can be dynamically coupled to Homey, like linking the color of a light to a background element. It has also lots of style templates. It generates a webpage, which means any device with a modern browser can display it.
I should be clear that it is not as simple to use as the standard Homey Dashboard. However, if you want full control over the exact positioning and look of everything, this might be for you. There is no support for camera feeds though. I have looked into it, but getting a real-time feed inside a webpage is surprisingly difficult. I do show a camera feed, but it is sending snapshots URL’s ever 0.5 seconds to an image widget. It is currently in test mode, but feel free to check it out if you are interested:
