Remove Z-wave device
Hi
I have a few Neo Coolcam power plugs that are added. They are not visible in the App.
When I go to
https://developer.athom.com/tools/zwave
I see some unknown node’s.
There are 3 dot’s at the end of each z-wave node line. The option ‘Remove’ is greyed out (this is the case for every node, not only those that are unknown).
How can I remove them, hoping that I can add the plugs again without getting the error that they are already added ?
Using firmware v3.1.0
Thanks
Click test after a few seconds remove should be available.
And you did removed them with…
Setting… zwave… remove device, and see whats happend?
