Can´t remove z-wave device
Hello. I had a device that didn´t work correctly. It was a Fibaro wall plug. I could´t remove it even when I had it. Now it was a year ago since I sent it back. I can´t remove it in the app because I don´t have a device to push the button three times on. I haven´t had any questions from the app to remove it. How do I remove it?
/Christer
Since it’s so long ago, i assume it should be unknown by now. Go to https://developer.athom.com/tools/zwave and look for the device there.
It should have status “unknown” as below example:
Anyway, click on the 3 dots at the end and if it’s allright you should have an option “Remove” there:
Click that option and it should be removed permanently.
Hence the " if it’s allright" statement…` :wink:
