Do you know if the device ‘skumregel ?’ is actually fireing the alarm?
Does testing work (see if the devices on the ‘Then’ column actually turn on)?
The flow does not work when I test it. This is a Nexa relay for twilight( supposed to turn on when it gets dark and off when it gets light the outdor lights). I used to have this paired with a Nexa relay switch and it worked fine then. Its when I try it with my homey, it dont work. I`m new at this homey device, but hopeing to get it working.
