Rate Limit Error for Internal Weather info
Starting this morning I get a Rate Limit Error on a card which determines the avarage Outside Temperature.
After some looking further into it, it seems a issue created by the Temperture “distributed” by Homey.
Also the insights of all the “internal” weather info aren’t changing anymore.
What could be the problem ? Tried a reboot but it didn’t solve the issue.
Probably this card is triggered too often, is it more then 1 time per minute?
@JPe4619 Nope it is triggered once per 10 minutes
I have no clue.
Just to rule out potential sources of error. Is your location in the settings still correct?
@DirkH , it is checked that one also allready, but thank you for the tip ! Every tip, question is welcome because there could be a blind spot I’m missing
