When a flow is started and the “INNR SP 240” switch is turned off, the flow does not proceed and therefore does not send a message to the Google spreadsheet.
Is there a way to ensure that the INNR to proceed ?
continues?
Thanks for the information but I did explore that via the smartPhone it is working, only the flow has to “think” about 13 seconds to go further!
Continuing the discussion from Question regarding the INNR SP 240 switch being off:
This is most probably caused by running it as Test. Test mode simulates the flow at a (veeeeery) slow speed.
When running the flow in “normal” mode, the delay shouldn’t be there at all.
