I have created a flow to check if a PS4 is switched on. I let my router check if the device is on every x minutes. When it is on, it sets the variable to “true”. It worked until yesterday. Now the variable is set, whether the device is on or of. See below screenshot. Homey knows the device is off, but executes the command nonetheless… What am I missing here?
I only know of some qwerk in the web interface if you change something and didn’t save testing will give strange results sometimes. Save reload the page and it should work correctly.
If you can reproduce the issue you could create an issue on GitHub, but you need to be sure it isn’t an issue with the application for the router.
