I tried adding a Qubino Flush Roller shutter module ZMNHCD1 on my Homey, unfortunately he does not recognize this device.
Then I added Fibaro roller shutter 3. However, this works through a slider which is not good for my application because there is no stop position. Where I am looking for is a switch device that operates a motor for turning anti-clockwise, clockwise and a stop position. Could you advise me?
Maybe this is an option for you:
you can make 3 flows for the Fibaro:
1 goto 100%
2 goto 50%
3 goto 0%
these flows you can start via Virtual devices
For the Qubino, you can request Athom an addition to the Qubino app for your device ZMNHCD1
https://github.com/athombv/com.qubino/tree/beta
You could try and install the beta from cli. If you look at the changelog it reports:
Improved support for Flush Shutter (ZMNHCD)
You could give it a try. Obviously since it is a beta and you can only install this version through cli, nobody gives you any guaranties.
– except for max ![]()
With the Qubino beta App this works
Jan , thank you for tour advice. I’ll try and as Athom how tour add the quibino shutter
Gr Theo
Verzonden vanaf Samsung-tablet.
-------- Oorspronkelijk bericht --------
