I’m considering to switch to Homey but I have many (10+) Qubino flush z-wave dimmers and want to make sure that Homey is compatible with the Qubino dimmers first. Curently I’m using the extra inputs (i2 and i3) on several of the Qubino dimmers to trigger different scens (flows). I found on z-wave.se/comp/ that the inputs i2 and i3 cannot be used to trigger flows. Does anyone here know it that is still the case? That would definitely be a show stopper for me.
Thanks in advance!
Yes. You can use i2 and i3 to trigger flows.
Great. Thanks!
Hi Jonas,
It seems that this feature does not work at me. Is there anything under the advanced settings what needs to be set?
Configuration parameters
Parameter no. 1
Input 1 switch type
Available
config. parameters (data type is 1 Byte DEC):
default value 0
0 mono stable switch type (push button) button
quick press turns between previous set Dimmer value
and zero
1 bi stable switch type
NOTE: Switch connected to S1 terminal is a master switch.
It activates the basic functionality of the Dimmer
Parameter no. 2
Input 2 switch type
Available config. parameters
default value 0
and zero
NOTE: to enable this function, Parameter 20 or Parameter
100 has to be set.
Parameter no. 3
Input 2 contact type
default value 0
0 NO (normally open) input type
1 NC (normally close) input type
Parameter no. 4
Input 3 contact type
default value 0
Parameter no. 20
Enable Disable 3way switch /
additional switch
Dimming is done by push b
utton or switch connected to I1
(by default). Enabling 3way switch dimming can be
controlled by push button or switch connected to I1 and I2 .
Available config. parameters (data type is 1 Byte
default value 0
0 single push button (connected to
1 3 way switch (connected to I1 and I2)
2 Additional switch (connected to I2)
