Problem with the variables from the homey device itself. It saves automatically
See picture:
Changed post. / End post.
I mailed:
Support | Homey .
Regards Daniel.
The second one is set to 13:19, not 13:39.
Also, are you sure that “de tijd is tussen” card includes the end time?
1
1
But your example flow, about which you said wasn’t working, doesn’t even use variables?
1
So lessons learned: post the actual flow that you’re having issues with, not a flow that’s not faulty.
1
1
1
I lost track on what the actual issue is and what Athom should change.
In any case, this is a community forum, if you need to contact Athom you can submit a support request.
1
1
1
1
See # 7 and # 10,
The community is not the place communicate official with Athom or to place “Urgent” request to the Athom developers.
Pls use the above support links.
Please give me the link for the dutch forum and i will place it there. Then you can remove the whole topic.
