Problem with Tapo Light?
Hello, I have a problem with Tapo lamps (GU10, L630).
I need to pair them via the Tapo app and then integrate them into Homey—so far, so good.
But when I try to control them through Homey, there is some latency, and on top of that, they bug out (sometimes half of them turn on/off, sometimes only one, sometimes two, sometimes three, etc.).
However, when I use the Tapo app, there is zero latency and no lighting issues.
Does anyone have a solution?
Thanks!Hello, I have a problem with Tapo lamps (GU10, L630).
Thanks!
This is probably because you turn more than 2 or 3 devices (using the same protocol) at once.
Homey unfortunately sends the signal to all those devices at once, instead of sequential.
This causes signals getting interfered / lost.
Workaround: group those devices by using the < group > app, or an Advanced virtual device.
Those apps start the group members sequentially.
Helo @Peter_Kawa and @Yannick_Neyns
I have similar problem as you describe (specificly with GU10 L630)
anyway from my point of view there are two problems
  • big delay when turning on/off (I could live with that) - in contrast with TAPO app, where it works very swiftly
  • inconsistency (sometimes some of the ligts dont turn on, or also changing colors is often buggy) - this is a big problem for me
I tried the < group > app to solve the inconsistency but it behaves the same (very often at least one of the lighst does not turn ON or when turning OFF one or two stay on)
a janky workaround that sort of works n is following: in a FLOW not turning them all at once, but in a sequence (in my testing I even added 1 second delay inbetween each light turning on), to be safe, I even spammed the sequence multiple times (so that if any of the lights did not turn on in the “first round” it will in the following round)
From user perspective the problem is that in the HOMEY system the light turns OFF but in reality it does not - this sometimes happens even if i try to turn OFF the light via the Homey APP (through the devices overview) - the icon that represents the light shws “TURNED OFF” but in reality it emits light
Similar problem is also with changing colors, sometimes changing colors (either way by input from user in the devices overview in HOMEY app or through a FLOW) - from my experience there are more cases of the color not changing than working properly (also in the HOMEY app it always shows on the icon that the color has been changed but in reality it has not). Curiously to me it seems that when not in RGB mode but in TEMPERATURE mode (different warmths of white) it seems to work with higher succes rate
For the lighst not reacting to color change I did not find work around (unlike with the Turning ON, the color often does not change even with SPAMING the light with order to change color)
Did any of you guys find a solution yet or moved on in any notable way?
Thanks, kind regards
Radim
Yes i let it go tapo light … wifi light doesn’t support several command in the same times … i send back all my tapo and bought Wiz working with matter , it works perfectly now ..
Hi All,
The app connects to the Tapo API. Unfortunately, this is limited to a number of requests that we can do. Normally this is per user, so you will not experience any problems with this. We are still in contact with Tapo to solve this.
I got tired of waiting, spent 80 euros to change the lights to tapo’s as they were given as compatible.
Now I end up with a lighting system that works intermittently, lights that don’t flow and all because there was no warning about the tapo API problem on the app or honey’s website.
Hi, any updates ? I am getting quite fed up with it to be honest and concider switching to IKEA
so I would like to know if solution on your side is something that is on the table right now
Thanks
Radim
Since there is no update in this question i guess there is no solution in near future either? I will do as the rest, skip Tapo light.
I have the same problem with the Tapo smart plug P100, works great in Tapo, great in Google Home by a lot of latency in Homey with a lot of failure.
I resolved the problem by doing a webhook in IFTTT and then a new flow in Homey. But this is not ideal sinc webhooks in IFTTT are only avialable in pro.
I’ve got two L930 lightstrips and am facing the same issues. Sometimes commands sent from Homey get there in 3-4 seconds, sometimes it’s a few minutes, sometimes it doesn’t happen at all. Pretty much everytime I turn on both of these lightstrips, one reacts in a few seconds and the other turns on 5-10 seconds later. They’re in the same room and are meant to be controlled together, but that seems impossible through Homey, even if I accepted the lag, since I can never be sure the command actually gets through. And the issue is the same even if I control only one of them.
If there’s anyone from the Homey team reading this, this issue has been in your backlog for quite a long time, perhaps it’s time to finally fix it? I mean, new integrations are exciting, but I think it’s much more important that the existing ones actually work.
Situation: When setting a Tapo lamp group off, all lamps goes off at the same time.
When setting a Homey (Tapo) lamp group off, they go off one by one (api blablabla).
Solution: Create a Smart Shortcut in Tapo app for all the lamps.
Make IFTTT applet (“Receive webhook” or "When Homey Flow runs) to Activate the Tapo shortcut.
In Homey use “Send webhook” or “Run Applet”
Done. All lamps goes off or on at the same time
