Problem with card "restart an app" SOLVED
Hello all,
I have a problem with the "then"card “restard an app” i get a red error card with the text: Can not read properties of null (reading toLowerCase)
Have more poeple this issue?
Dit you type the app name? Show your flow.
When i search an app name i get the fault. The list with app’s is empty when i try it on the phone.
The flow is verry simple, “This flow is started” and the then part is the restard card.
I wonder if it’s related to the “Missing owner name” error. You should probably ask Athom.
What is the “missing owner name” error ?
https://community.homey.app/search?q=%22missing%20owner%20name%22%20order%3Alatest
Just updated to FW12.0.0 but unfortunately still the same problem, cannot restart apps with the mentioned DAN card.
But another email was sent to Athom.
Not sure if emails get processed
Browsing to https://homey.app/support is the way to go
I did it through support.
Problem has been resolved with help from support. It turned out that I still had the LEDring collection app on Homey. After uninstalling this app, everything works properly again
