Problem with attribute reports callbacks
Hi, I’m developing a zigbee lock and a matching homey app. I have got so far as to sen unlock/lock commands to the lock and that is working.
Now I’d like to get attribute reports for closureDoorLock/lockState and battery alarms or measurements but I wont get any callbacks, even if I see the reports in the debug log. (i’m missing the console.log('onLockStateReport ’ + report); calls, see below)
This is probably a rookie javascript error, but I’m stuck so any help is appreciated!
device.js:
'use strict';
const ZigBeeDevice = require('homey-meshdriver').ZigBeeDevice;
class UwLockZigbee extends ZigBeeDevice {
    onMeshInit() {
        console.log('UwLockZigbee onMeshInit called...');
        this.enableDebug();
        this.printNode();
        this.registerCapability('alarm_battery', 'genPowerCfg');
        this.registerCapability('locked', 'closuresDoorLock', {
            endpoint: this.getClusterEndpoint('closuresDoorLock'),
            set: value => value ? 'lockDoor' : 'unlockDoor',
            setParser: () => ({pincodevalue: '1234'}),
        this.registerAttrReportListener(
            'closuresDoorLock', // Cluster
            'lockState', // Attr
            1,   // Min report interval in seconds (must be greater than 1)
            0,   // Max report interval in seconds (must be zero or greater than 60 and greater than min report interval)
            1,    // Report change value, if value changed more than this value send a report
            this.onLockStateReport.bind(this))  // Callback with value
            .then(() => {
                // Registering attr reporting succeeded
                console.log('registered attr report listener');
            .catch(err => {
                // Registering attr reporting failed
                this.error('failed to register attr report listener', err);
            'genPowerCfg', // Cluster
            'batteryPercentageRemaining', // Attr
            this.onPowerCfgBatteryPercentageRemainingReport.bind(this)) // Callback with value
            .then(() => {
            .catch(err => {
            'batteryAlarmState', // Attr
            null,    // Report change value, if value changed more than this value send a report
            this.onPowerCfgBatteryAlarmStateReport.bind(this)) // Callback with value
            .then(() => {
            .catch(err => {
    onLockStateReport(report) {
        console.log('onLockStateReport ' + report);
        this.setCapabilityValue('locked', report.value === 1);
    onPowerCfgBatteryPercentageRemainingReport(report) {
        console.log('onPowerCfgBatteryPercentageRemainingReport ' + report);
    onPowerCfgBatteryAlarmStateReport(report) {
        console.log('onPowerCfgBatteryAlarmStateReport ' + report);
module.exports = UwLockZigbee;
app.json
  "id": "se.unitware.uwlock",
  "version": "0.0.1",
  "compatibility": ">=1.5.0",
  "sdk": 2,
  "name": {
    "en": "uwlock"
  "description": {
    "en": "Connect the uw lock via zigbee"
  "category": [
    "security"
  "permissions": [],
  "images": {
    "large": "/assets/images/large.png",
    "small": "/assets/images/small.png"
  "drivers": [
        "id": "uwlock",
        "name": {
          "en": "UwLock Driver"
        "class": "lock",
        "capabilities": [ "locked", "alarm_battery" ],
        "energy": {
               "batteries": ["AAA", "AAA"]
        "zigbee": {
          "manufacturerName": "unitware",
          "productId": [
            "uwlock"
          "deviceId": 10,
          "profileId": 260,
          "learnmode": {
            "image": "/drivers/uwlock/assets/learnmode.svg",
            "instruction": {
              "en": "Unlock the lock on the keypad, wait for leds to go out, swipe, hold button #4 for a while, enter unlock code again."
log
─────────────── Logging stdout & stderr ───────────────
2020-06-08 16:53:34 [log] [UwLockApp] UwLockApp is running...
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ZigBeeDevice has been inited
UwLockPlugZigbee onMeshInit called...
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ------------------------------------------
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] Node: acf5cb1c-26e4-4aca-a81c-b9aa30258803
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] - Battery: true
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] - Endpoints: 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] -- Clusters:
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] --- zapp
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] --- genBasic
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- cid : genBasic
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- sid : attrs
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- zclVersion : 2
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- appVersion : 1
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- stackVersion : 10
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- hwVersion : 11
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- manufacturerName : unitware
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- modelId : uwlock
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- dateCode : 20200420
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- powerSource : 3
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- swBuildId :
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- deviceEnabled : 1
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- locationDesc :
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- physicalEnv : 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] --- genPowerCfg
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- cid : genPowerCfg
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- batteryPercentageRemaining : 36
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- batteryAlarmState : 1
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] --- genIdentify
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- cid : genIdentify
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- identifyTime : 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] --- genGroups
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- cid : genGroups
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- nameSupport : 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] --- genScenes
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- cid : genScenes
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- count : 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- currentScene : 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- currentGroup : 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- sceneValid : 0
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] --- closuresDoorLock
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- 1 : 2
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- cid : closuresDoorLock
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- lockState : 2
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- actuatorEnabled : 1
2020-06-08 16:53:52 [log] [ManagerDrivers] [uwlock] [0] ---- doorState : 1
2020-06-08 16:53:53 [log] [ManagerDrivers] [uwlock] [0] registerAttrReportListener() -> configured attr reporting attrReport_0_closuresDoorLock_lockState
2020-06-08 16:53:53 [log] [ManagerDrivers] [uwlock] [0] registerAttrReportListener() -> configured attr reporting attrReport_0_genPowerCfg_batteryPercentageRemaining
2020-06-08 16:53:54 [log] [ManagerDrivers] [uwlock] [0] registerAttrReportListener() -> configured attr reporting attrReport_0_genPowerCfg_batteryAlarmState
2020-06-08 16:54:11 [log] [ManagerDrivers] [uwlock] [0] [dbg] report {
  token: 'acf5cb1c-26e4-4aca-a81c-b9aa30258803',
  device: '0xf4ce3674f36f5aed',
  endpoint: '8',
  cluster: 'genPowerCfg',
  attr: 'batteryPercentageRemaining',
  value: 36,
  event: 'report'
  endpoint: '8',
  attr: 'batteryAlarmState',
  value: 1,
  event: 'report'
And what does the “1:2” mean inthe printNode()?
Found a possible bug:
@unitware you did not define the optional endPointId in the registerAttrReportListener. But it will assume 0 as the default endPointId.
Apperantly the device is reporting on a different endPointId then what it is / has been announcing during the cluster endpoint interview phase of the inclusion step (as shown in the printNode overview).
Current work-around, until Zigbee rewrite is released, is to manually define the AttrReportListener as shown in this example:
Which should become something like:
this._attrReportListeners['8_ closuresDoorLock'] = this._attrReportListeners['8_ closuresDoorLock'] || {}; this._attrReportListeners['8_ closuresDoorLock']['lockState'] = this. onLockStateReport.bind(this);
That will solve your issue.
hi, thanks for your reply!
I did try the optional endpointId argument but that did not work since the andpoint array is not that big. This led me to believe that the actual endpoint numbers were abstracted and all endpoints were put in a array starting from index 0.
I’m sure your proposed workaround will work also, but I think mine is a bit cleaner and might even survive an updated stack where the endpointId moves from 0 to 8. maybe :slight_smile:
Is the zigbee rewrite pending soon? (good to know when planning my project)
Rumor has it that the Zigbee rewrite will be pending :soon:… no guarantees though.
so there will not be any updates on the Zigbee side of the meshdriver
Sorry about posting in an old thread, but is the app you making going to be for generic zigbee lock? I have a zigbee lock that is currently not supported and struggle to add it to Homey with correct functionality.
Homey doesn’t support generic Zigbee device apps, you need a specific app that supports your device.
