Problem geting button presses from shelly in to an flow
I have:
-shelly BLU wall switch 4
-shelly Plus 1 PM
They are added and connected in the Shelly standalone app.
Setting up a flow that reacts on button presses in that App works.
I have now added both devices to homey as well. I have also turned on bluetooth proxy on shelly Plus 1 PM.
The problem is that nothing happen when I setup a flow that should triggar on a button press?
Anyone knows how to get it to work?
Echoing @Roger_Jonsson on this matter. I experience the following (on Homey Pro 2026)
  1. The button switch is not listed as a specific device neither in the old Shelly App, nor in the new beta app, so it is not possible to choose to add it as a Zigbee device (as it does not exist)
  2. Alternative solution could be to use it as a Bluetooth device (although Zigbee is preferred). However, although adding it as a “Any Shelly Bluetooth device” makes the device show up in Homey, the button presses do not go through. Although, I can select the short single, double, tripple, and long presses as actions to my flows, the actions seem to never come through to the Homey flows.
Have reached out to Drenso hoping to get it fixed/included in the new Shelly App (currently in beta).
Also experiencing the same with the Shelly BLU RC Button 4.
Can pair with Homey and the device shows up and seems connected fine. I can make flows using the Switch options as triggers but the flows never (or very rarely) trigger. If I trigger the flows through the app directly they work consistently as expected.
I have updated the switch firmware, re-added multiple times. Not sure how to resolve - is there a new updated Shelly app coming? Happy to help test a Beta if this issue is covered under the improvements etc.
