Is possible to add a filter by string part
I donāt know, but at me HomeyImage with image from app Gallery work
v0.240624.1 - release 1.4.67
- Bug fix
I also installed the gallery app and uploaded a simple image. When I add an image widget to the NSpanel, I do not see a preview of the image and is therefore not shown after saving. I donāt understand why it works for you. Is there anyone who would like to think about what I may be overlooking? On my iPad I can see the image in SmartDash.
Can you try to set cloud_id in ns panel pro and connect by cloud?
v0.240626.1 - release 1.4.68
- Added url of image in HomeyImage @Johan_Huisman try this update: edit a HomeyImage widget and copy the url of image. Open a browser, paste it and check if the image is showed
You helped me on the right path. after adding a Cloud ID, SmartDash indicated that Homey was offline. I restarted my Homey and now I can start SmartDash via Cloud. The images now also work and I see my doorbell image. Thanks for your explanation.
In the latest week i have some problem with homey (cloud donāt work very well), maybe you are in the same situation.
I read in another forum that Homey Pro 2023 regularly loses its cloud connection. They will then restart the Homey every day. Iāll keep an eye on it to see if it continues to work.
However SmartDash has a problem when Homey restart (some time lose the connection, need to restart the app). Iām fixing this issue (need to recreate authentication)
Switch Bot pro Lockā¦
I have installed a Switchbot Pro lock on my door(s). It is compatible with Homey. But I cannot add it in the DashBoard. What do you need to add it ?
If smartdash find the device send a screenshot of capabilities and the device type
I already found it⦠I named the lock incorrect. So I could not find it as I expected.
Can you give me an example of the CSS code for locked (red button) and unlocked (green button) ?
v0.240628.1 - release 1.4.69
- Optimized messages when Homey cloud is offline
is the same of a socket widget.
the system add .on class when is locked (or unlocked?).
.content .state { color: green !important }
.on .content .state { color: red !important }
@diapolon after updating I get this on smartclock, before update it was working.
hi, i released a fix. I donāt know what happened but in the last update it was deactivated the http cleartext in ns panel pro version
v0.240628.1 - release 1.4.70
- Fixed HTTP ClearText problem in Ns Panel Pro version
Thanks, is fixed!
@diapolon I hope you keep up the good development of SmartDash despite the change of Athom ownership. I would like to see it as a hobby, not as a paid project.
