Hello I have an android device.
Thank you for your hard work
ok i publish update in android play store
update released, check if work!
Hello Diapolon, the update for android has solved the problem with the Gost Widget. Everything works again without any problems. You have built a 5 star app.
Very good i release fix for iphone too
v 0.240524.1
- Fixed GhostWidget problem. Thankyou @Ton_van_Rijnsoever @Amersfoort @Hielke_de_Jong
Would you be willing to do a short write up with examples of how to change via css the layout and such? I’m not a programmer, and the seperate snippets arent enough for me to fully understand it.
Being not a programmer too and never worked with CSS, I learned the best from the examples and trying myself (with checking the site: CSS Tutorial for some explanation).
Advice: start small For instance changing background, then try to change background for on/off state of widget (copy examples you can find in this topic by searching for .content). Also I think it would help to know what you want to accomplish and what you tried.
Please give a specific configuration to setup. For example: how to setup the Sonos widget as displayed earlier in this topic.
I think it is not meaningful to publish all my CSS setups.
@diapolon “Long” time no hear! Any plans for SmartDash?
Hi, for now i’m little busy with others work
Nothing for Homey?
no
Actually i’m scheduled dashboard panels rewriting for fully manage the homey control variable system.
It require some time
This evening on Youtube there was a live interview with the two Athom founders for the 10th anniversary.
Among some other topics they told working an a official dashboard with possibility of add-ons by the community.
Are you working with Athom on a new dashboard, maybe with another Homey Dashboard app developer who is on the Homey forum as well. What are the consequences for the Smartdash app?
No
No consequences for Smartdash app if athom don’t remove local web api
Now I see the extra word “panels” in your post.
I’m fixed
Something different: how do you make the svg glow orange in Smartdash? Which statement do you use? Thanx in advance.
