[PRO][Dashboard] HDashboards a dashboard system fully focussed on Homey
Hi Menno. This worked for me from the start.
This is since this afternoon:
Restarted the Nest and Homey.
Loged out and in on HDashboards.
I have only one Homey early 2018.
Should work again :smiley:
1 Dashboard multiple Homeys!!! It’s now possible!!!
Release v0.6.0
  • Added mutli homey support (Access via website)
–^ A huge update that lets you make dashboards with multiple homeys. 1 dashboard can control multiple homeys.
  • Added Support for displaying variables (Coming to multitile soon)
  • Added Main dashboard is now really your main screen
  • Solved issue objects where misplaced after edit
  • Solved access issue for sub users who could access dashboards via dashboard cards
  • Solved 1% battery displayed as 100%
  • Solved whitebackground companion app text unreadable
  • Solved issue thermostat card doesn’t show onoff status
  • Solved issue with image url’s
  • Potential fix for images freezing
  • Solved issue where border disapears in multicard
Cloud updates:
  • New system for billings → subscriptions
  • Can buy multiple licenses for multihomey
  • Multihomey costs 20 euro’s per homey extra
Probably stupid question.
But to set color in app Hdashboard Companion I need a numeric identifier .
Where can I find that ??
If you edit an card. It’s on the top of the edit popup.
Soon it’s configurable in the hdashboards app. So you can give cards the same identifier. And it will be alpha numeric.
How to
Change color background from a dashboard
Custom not yet. But under settings you can choose between light or dark atm
Release v0.6.3 being shipped right now
  • Added RTSP livestream support as experimental (YES LIVE CAMERA’s in dashboards)
  • Added duplicate button for dashboards
  • Added system that only shows last notification of button that is pressed
  • Added refresh button for dashboards
  • Added lock buttons to long press
  • Added background color to timeline and clock cards
  • Added date autoscale for analog and digital clock
  • Added priorty longpress to list ipv sensors
  • Restyled multitile flow card → normal flow card
  • Fixed color picker for color lights
  • Fixed timeline card not woring on subaccounts
  • Fixed text button names not updating
Release new cloud version:
  • Better support for sharing blog items (Taking correct image, title, subscription)
Release v0.6.4 being shipped right now
  • Added mute option to video card
  • Added click for fullscreen for videostream card
  • Fixed editing off cards
  • Fixed video resume on back in app
  • Fixed duplicate dashboard multitile
  • Fixed buttons not able to turn of via HDashboards
  • Changed error text video stream cards, since limitations by web down allow rtsp
  • Stability improvements
  • #00 on comments will now be transformed to a working link
hoi kan iemand mij uitleggen hoe je weer informatie op een dashboard kan weergeven?
dank
hi how you add buienradar to youre dashboard? wich Link should i use
Hey ik raad aan om discord of fb te groeien. Weer kan via de open weather widget met de image url. En buienradar met https://gadget.buienradar.nl/
@Menno_van_Hout @Frits_Raats
Multilingual on the Homey community - Why not discuss in different languages on forums?
Are you planing to support some kind off Interactive map? Should be cool to point at the room you wanna clean on a map or see the room on the map light up when the lights is on. Find some example on google. Mabey it is not even possible? :slightly_smiling_face:
Hey Daniel,
This is something on my planning for sure!
Just not too soon sadly, but it will definitely come. I already thought about how to implement it.
All through redesigning the add/edit cards screen and changing some behaviour has my priority right now.
Looking forward to your continuous work :slightly_smiling_face: will be very interesting.
Menno, I am in Australia. Could this be the reason I can’t open your website?
Hey, should work. What is going wrong?
I get can’t open, can’t establish secure connection to server. Everything else is working. Have tried Chrome and Safari, and ipad and Macbook.
It must be something to do with my IP Address. If I turn off wifi and use 5G it is OK. But that probably won’t work for everyday use.
This is what I get trying to login over wifi.
I’ve now worked with both tools and I must admit SharpTools has a good homey integration and specific things you just add yourself.
