[PRO][Dashboard] HDashboards a dashboard system fully focussed on Homey
@Menno_van_Hout It is true that the PIN code works on the web app, but not on the iPad and iPhone?.Today my tablet comes to hang up. I had created the dashboard and set the PIN codes on the laptop, but it does not work on the tablet.
@Ria_Banis
Hoe heb je de tegels voor je rolluiken gemaakt? Ik krijg enkel een slider, al van alles geprobeerd. Maar wil ook graag de pijl omhoog en omlaag.
I use the tile device.
Just a screenshot of the settings. I use an Asun650 from KaKu
The status color with the Companion app. KaKu does not retain the status. Open: green, closed: red
@Ria_Banis, @Anthony_Pranger, @DaanV: Maybe good to switch your discussion to English and translate the existing posts. You are commenting in the English section of the forum; not the Dutch section.
@SunBeech done from my site. Sorry for the inconvenience
Hi Ria,
I did that but it won’t work on the Google Hub. But no problem, i use a Ipad also.
I really like the possibillity to add a pincode. But how does that works on multicard? I can set a pincode, but I’m never asked tot enter the code. I can control eveything on the card without entering a pincode. I would be nice if you could require a pincode for a single item on the multicard.
Multicard support is coming soon.
Today I was accidentally logged out of my Nest account in HDashboards. I’ve been trying for a while and found out that casting to the Nest initially only works if you give the Nest account (I created a separate user) all the rights. Then copy the link and copy it into your flow. Later, you can change the user permissions for the Nest accout on another device. I hope this helps you. If it’s unclear you can send me a DM.
Is there a way to hide titles from a device-card?
@Menno_van_Hout Could you please apply max-font-size to the digital clock? I will make a nice donation for that little feature.
I changed the title of a card through the compagnon app. But how can I delete it so the standard title will be shown?
Try setting it to a space bar " ".
In most cases it will try to load in the default title if possible.
I tried, but the fontsize is very small then. I think because with a space you make an invisible title.
The right one is what it should be and the left one is with the invisible title.
I will add a reset option card soon! as this is also the correct way of resetting backgrounds.
Will work on that next week.
Great, thanks! Same thing with the tiltle. If I set a space, there is not title vissible. Hope the reset option will fix that too :slight_smile:
Is it possible to reset an icon to it’s default one in a card? I submitted it a while ago but I don’t know if that’s the right place.
And also it would be nice if you can choose an icon from other apps installed on your Homey.
it’s the right place im going to focus on the requests again after the holidays.
Putting a space doesn’t work. It will use the default title. My use-case is the following. I have a section on the board with the weather. The current temperature doesn’t need a title, the fact that it displays 9°C tells me enough. But i’m required to set a title unfortunately.
btw. one other thing, i added a Insight to the board. Very awesome. But it doesn’t update during the day. Its static. Is there a way to refresh that every x-seconds/minutes?
Bij het webdashboard kun je een ‘directe URL’ naar een specifiek dashboard opvragen. Deze URL gaat alleen altijd weer naar je dashboard waar je al je dashboards ziet en dan niet naar het specifieke dashboard. Ik zie namelijk dat de URL per specifiek dashboard anders is, daarbij zou je aannemen dat de specifieke URL, dus ook een directe link naar het specifieke dashboard, maar ze komen allemaal uit bij het algemene web dashboard (waar men alle aangemaakte dashboards ziet), terwijl ik graag de link zou gebruiken van een specifiek dashboard en die gelijk zou willen openen (in dit geval op een TV). Iemand ervaringen hiermee of gaat dat niet @Menno_van_Hout ?
Hallo Peter,
Dit hoort te werken ik schrijf het even op om er volgende week naar te kijken. Ik heb laatst de gehele fundering opnieuw geschreven, mogelijk een foutje!
