Powerplug outdoor
Does somebody has a tip for a outdoor powerplug ?
(zwave or zigbee).
I can only find the “Popp Tussenstekker Z-Wave” but i think that one is a bit overprised.
Peter
I have the Popp, does work as expected, only power metering isn’t that great. Not using it anymore though… z-wave range is pretty bad imo
I connected two normal outdoor sockets (IP54) via a Fibaro Double Switch 2 (FGS-223). The DS2 is installed in a waterproof splitting box (IP68).
But I had the possibility to hide the splitting box.
Ye, that’s what I did in the end, added a Shelly 1PM in the splitting box which was waterproof because it is outside.
Same here, no Zwave or Zigbee but a WiFi receiver in a waterproof box. I use SONOFF mini for this. Works great. Zwave range is not good enough.
If you have Gardena Smart Garden you can use the outdoor smartplug. Because you have in that case more gardena devices it will work smoothly. Only the prices are not smooth.
