Hello
I’m new to Homey and currently migrating from eedomus.
When including my Popp Z-Weather using the app, the humidity reading doesn’t seem to be reporting back.
I’ve tried excluding and re-including it, but the issue persists.
Am I the only one experiencing this problem?
May be my device is faulty, but the data was showing up fine on eedomus.
Thanks for your help.
According to the manual Z-Weather can reduce the interval of reporting data when the internal energy source is low. Maybe you need to wait a few days to see if it eventually reports all values.
I had this device years ago and I switched to other systems as i never was completely haopy with the device.
Thanks for the feedback.
I’m going to wait a bit to see what happens.
You mentioned switching systems. what setup did you move to, and, more importantly, are you happy with it?
Thierry
I am using now: Ecowitt Wittboy WS90 and Ecowitt Wittboy Gateway GW2000 Hub. Together with a Ecowitt Wireless Lightning Detector Sensor WH57. The GW2000 can be configured to push its data to a local address (Homey Pro). The Misol Ecowitt app supports GW2000 perfectly. In the setup you get the URL to enter in the GW2000. After that the device should come alive. And yes: I am absolutely happy with it. Only downside can be that the wittboy WS90 needs 2 AA Batteries that can get low in voltage over time so make sure to use decent ones that last long.
GW2000 Config:
