POPP Strike Lock reacts reversed
Hi all,
Something strange is going on with my new POPP Strike Lock.
Schema:
Schema strikeLock and magnetic lock_2
When I press “Unlock” in Homey, I measure 12V between pin 1 & 5.
When I press “Lock” in Homey, I measure 0V between pin 1 & 5.
Of this should be the other way around of course! My Magnetic lock works (“locks”) when current is applied. And no, switching pin 1 & 5 doesn’t help.
See the following movie for some live action: https://www.dropbox.com/s/27i58xisyzz9h2y/StrikeLock%20behaviour.mp4?dl=0
Any idea(s) ?
Hi Roy,
The device is attached to a 230V AC to 12V DC transfo. So no battery drain risk.
The magnetic lock that I’m using requires power to be locked.
But changing 6 with 4 did the trick!
Many thanks for the quick reply and solution.
