Open app in the right room
why don’t create an option that consider the last sensor activated (for example presence sensor) and let the app know where you are. Mean when you go to open it the first screen you will see is the room where you are :wink:
That only works if you’re the only one in your house and you don’t have pats, running around.
Yes and no, can be work with different type of sensor and algorithm. For example if you turn on the light.
And, when somebody else turns on the light?
Thinking loud, can be deactivate if more than one person are wake up or in the house. To test it I need the feature in the flow to select the opening app tab
