hi there, i’m using an old ipad as a dashboard.
when i’m starting certain flows, i like a audio warning, (example : heimdall, starting toezicht, homey says “toezicht aan”)
is it possible when i’m starting flow from ipad to hear this audio message on ipad?
thnx
jo
I do not know of a way to do that, but you could put a Google Mini close-by and cast messages to that using the Google TTS app.
Look at this
[DSC08296-FB]
I really wanted a dashboard in the wall to control everything I want. Last couple of week’s I’ve discovered homey-dash. Great I thought, and build an old iPad 2 inside the wall. Sadly, the dashboard was very limited. I could only start some flows, and control some switches. To see information on some devices, I needed to press them several times, and to use a slider I needed to long press a device. I thought I could adjust my electric blinds, but sadly the slider didn’t work for …
Or use the new web app My Homey
Both works great on an old iPad.
Hugo
January 10, 2021, 3:43pm
4
I have an ipad 3 and the new web app from Athom does not work on that type but the old Homeydash dashboard works well.
old dash is working, but sound was the problem.
can i cast to ipad?
Same issue here. Would be great yo give my old Ipad mini (running on IOS9) a second life, but my.homey.app does not work with any webbrowser
i installed homeydash, is working for me.
just copy url, and dash is showing
