Not registering button events
I recently moved from Home Assistant to Homey. The last device I moved over was an Aqara Opple 4-button switch. It worked without any issues on Home Assistant, but I’m having trouble with it on Homey.. When I press a button, nothing happens. After several button presses, it sometimes eventually responds.
The Opple is only about 3 meters from my Homey Pro 2026 and is currently connected directly to Homey.
In order to figure out what causing this I created a very simple test Flow:
Button pressed → push notification
The notification is not triggered, so it seems that Homey is not receiving the button press event at all.
I initially suspected a Zigbee/network issue. I checked the Zigbee network in Developer Tools. The Opple initially routed through an IKEA plug, so I unplugged that plug. The Opple then connected directly to Homey, but the problem remained.
Since I wanted to keep controlling my roller shutters, I decided to try an IKEA BILRESA Dual Button (Matter over Thread) instead. Unfortunately, I’m seeing exactly the same behaviour with the BILRESA.
The BILRESA is online and connected to my Thread network. I also created separate test Flows for the upper and lower button but neither Flow is triggered.
I have also restarted Homey, but this did not solve the problem.
So at this point I have two different buttons using two different protocols. both devices appear online/connected, but button press events are not reaching my Flows.
This makes me suspect that the problem may be somewhere in Homey itself, the app integrations, or the processing of button events, rather than the physical buttons or the wireless protocol.
Has anyone experienced something similar, or can suggest what I should check next?
This is a known issue, see the Aqara app topic for more details:
Thanks! will wait for an update here.
But what about the matter button that isn’t working?
Others have got the Bilresa to work. Mine connected OK, but after a short while it hung and nothing worked until I did a factory reset then it went back through the same cycle. I returned it. I guess it was a hardware issue.
Andy
Hi @Lazyeye,
Your post could have been mine. I see almost exactly the same behaviour on my Homey Pro 2026 (firmware 13.5.2), and I’m wondering if you’ve made any progress since.
My situation:
  • I moved from SmartThings to Homey with the same Zigbee devices. On SmartThings everything worked reliably for several years.
  • On Homey, button and sensor events are missed intermittently: sometimes a press works, sometimes Homey doesn’t react at all. Roughly one in three presses is lost. Devices: IKEA STYRBAR, IKEA 4-button remote, Aqara switch and Hue motion sensor, so several brands.
  • Outgoing commands from Homey to lights always arrive fine. The problem seems to be on the receiving side.
What I’ve tested:
  • Factory reset plus firmware reinstall via the USB tool, then a clean setup with only two buttons (IKEA and Aqara), paired directly to Homey with no routers at all in the network, and a single flow that colours the LED ring. Even in this minimal setup about a third of the presses were missed.
  • Moved Homey to another room, and tested on both Ethernet and Wi-Fi. Zigbee is on channel 25 and there are no Wi-Fi networks at all from channel 8 upwards.
Support: I have an open ticket with Athom (#156292). They respond, have reinstalled the Zigbee chip firmware and enabled extra debugging, and I’ve sent several diagnostic reports with exact timestamps of successful and missed presses. Unfortunately the feedback so far has mainly been general advice on building a stable Zigbee network, not anything that explains why events are missed in a clean setup without a mesh.
Since you also saw this with a BILRESA over Matter/Thread, it really looks like something in Homey itself rather than the buttons or the protocol.
Could we join forces?
  • Did you get any concrete feedback from Athom beyond “known Aqara issue”? And does your BILRESA work by now?
  • If you have a support ticket, could you mention mine (#156292) in it? I’ll reference yours as well. Linking the cases should help Athom see this is a pattern, not an isolated mesh problem.
  • Anyone else with a Homey Pro 2026 seeing intermittently missed button or sensor events? Please reply with your model, firmware version and devices, so we can see whether there’s a common factor.
Thanks!
Arjan
