Newbie: dynamic contract + solar +battery +heat accumulators +boiler +PHEV +smart thermostat
Dear,
I am a complete newbie with Homey, and I need some guidance for the first project for my parents.
They live in a house that used to be heated solely by heat-accumulators (they used to have a special contract for the accumulators). (model: Dimplex CXL S24N)
Since some renovations they also have a gas fireplace.
They currently have solar panels with a non hybrid inverter.
They also have a Mercedes PHEV.
The plan is to:
-convert to dynamic energy contract (power by the hour)
-install an hybrid inverter (probably Growatt) with 10 kW of battery power (and a smart meter)
-install a homey compatible smart thermostat
What I want to achieve (all through AI and smart usage of the dynamic contract):
-charge the heat-accumulator during the cheap hours (mostly during the night, if needed around 12h we also have a pricedip)
-charge the boiler at night and with any excess solar production
-charge the PHEV at night
-charge the battery at night (if no or little solar is expected) and use the battery for all electrics untill we are back at low cost energy
What I think I need.
Homey Pro
DIN Rail Smart Switch for charging the heaters at night
DIN Rail Smart Switch for the boiler
Smart Plug for the PHEV
Questions:
-what app is the best to use to predict the solar production (no need to charge the boiler/PHEV if the next day the sun will shine)
-can Homey/the smart thermostat “calculate/adjust/learn” how much we need to charge the heat-accumulators at night in order to have a good temperature during the next day?
I still need to check if the Gas-Fireplace can be automated (to use it if it’s cheaper then charging (recharging around 12h) the accumulator, offcourse it’s always a good backup!
Thanks
Tanguy
I would suggest to start with a more simple project. So you get an idea of the complexity of your question and the required hours of effort.
I agree with RMB, this is very complex to build.
Usually this is how it works: you show the flow(s) you could come up with, and we can help improve and/or share ideas on how to proceed
Homey can calculate “anything” you like.
But how to calculate this, is out of my league
This gives a hint:
thanks for the reply’s!
I have some homework to do now :wink:
You can use my car charging flow on surplus solar as inspiration.
Its really working well to reduce excess solar to almost zero
Sounds like you also need to think about load balancing…
Ttyese are all high power devices, you do not want to blow you main fuse.
