Hi, i like the new UI where you tap in the corner of a device to toggle it. But i do think that each device should have a setting where you can choose between tapping the entire device or the quick action button in the corner. A setting where you choose quick action, entire device tap or maybe even both. Tapping device: turns on/off, tapping the quick action does what you selected it to do in the device settings which you already can do. I think that would be kinda cool update, instead of being forced to the new UI, choose between the old and the new or just have both at the same time.
I like the new button for device quick control. I wish at the bottom where it shows on/off for plugs it would show on/off if i said it has a fan plugged in but it does not. I have not gone through all the other options for what’s plugged in but so far I only see on/off I select light is plugged in.
Yeah, the reason i want to be able to choose atleast on some devices is that my dad prefers just tapping the entire device. But we both also like the new UI.
