Not sure what country you are from, but check Plejd.se, if it is available in your country, it is a no brainer, there isn’t any other lighting system that compares with it. Easy to install, electricians love it and the system i bullet proof, never fails and easy to use, stand alone system that works with Homey
A few months have passed and the renovation is progressing steadily. I sold my house including Hue, Somfy, Netatmo CO₂, and Zehnder ComfortControl, so I am setting everything up again from scratch in the new house.
At the moment, the configuration is as follows:
Sigenergy battery system with solar panels (I still need to choose an EV charger)
For lighting and switching: Shelly
Nibe S ground-source heat pump with Watts Vision zone control. I have not found an integration with Homey.
Ajax alarm system and cameras (also still looking for a Homey integration). Ajax is also used for garage door control.
Yale Linus L2 for the door locks
Because of the Watts Vision thermostats and Ajax, I considered starting with Home Assistant, but the system does not really appeal to me.
My current idea is the following:
To install a rack-mount PC running Proxmox, with Home Assistant on it for Watts and Ajax. In addition, I would run Homey on Proxmox and connect it to Home Assistant, so that the Watts and Ajax entities can be exposed to Homey.
Oh, and I almost forgot to mention: we also have some Varin Tuya lights with an integrated fan.
And how do I do it? Using this protocol, it won’t let me arm or disarm the alarm… can it be done via a proxy? And should I have a proxy server just for this?
