Hi. I want to buy a Nest Thermostat v3 and connect it to Google Home and Homey Pro. I am not so sure if the thermostat and homey can do what I want it to do. I want to make flows that turns on/off a Fibaro (z-wave) switch when the thermostat turns on/off the heater. In the homey Nest app I don’t see events like “When heater is on” or “When the heater is off”, only “The temperature changed” and “The target temperature changed”. Should I use these events and store the values in variables (tags) to let conditions do turn onoff the Fibaro switch in the flows? Are the tags global variables?
Related topics
| Topic | Replies | Views | Activity | |
| Is there really no working Thermostat Valve to connect directly to Homey | 19 | 2782 | April 20, 2022 | |
| Get current temperature from Nest | 6 | 1074 | February 24, 2026 | |
| Add Nest thermostat to your flows! | 0 | 555 | July 4, 2021 | |
| Nest thermostaat koppelen aan Homey | 51 | 13681 | December 3, 2021 | |
| How to link thermostat with external thermometer | 23 | 3650 | December 20, 2023 |
