Nest Cam does not start a flow anymore when the cam notices a movement Inbox
Hi!
I have 2 Nest cams around my house and after 22:00 in the evening, when it notices a movement, a flow should start to trigger lamps (Philips Hue). It always worked, but since a few weeks, it stopped working. I see (in my Google Home), that the movement is registered, but no lamps will switch on.
I have more a these triggers, also for my alarm, when there is movement in the night, lights should turn on and an alarm sound should play. But also that flow is not triggered anymore.
Anybody else have Nest cams triggering a flow, and are they still able to start a flow?
Mark
Are you sure the triggers are the problem. Did you attach log cards (or timeline cards) to each flow part? This way you can discover at what point things go wrong:
Hi Peter!!
I did a test in the flow, and then everything works (start test at the cam, and every step is successful and the lights go on…)
Also, I created a simple flow (movement detected then send a message), but that also does not work.
I now created a diagnostic report and sent it to Athom…:slight_smile:
Mark
Hi guys
Any answer on this. I have the same issue here. No triggers from the cameras.
