When I try to include the Neo Coolcam single switch homey gives me a message that including has failed.
LOG:
| 2020-03-19T13:39:35.962Z | Command[78] start: removeNode |
| 2020-03-19T13:39:35.975Z | Command[78] status: removeNode, status: REMOVE_NODE_STATUS_LEARN_READY |
| 2020-03-19T13:39:38.001Z | Command[78] status: removeNode, status: REMOVE_NODE_STATUS_NODE_FOUND |
| 2020-03-19T13:39:38.720Z | Command[78] status: removeNode, status: REMOVE_NODE_STATUS_REMOVING_SLAVE |
| 2020-03-19T13:39:38.726Z | Command[78] status: removeNode, status: REMOVE_NODE_STATUS_DONE |
| 2020-03-19T13:39:38.730Z | Command[78] end: removeNode |
| 2020-03-19T13:39:38.742Z | Command[79] start: addNode |
| 2020-03-19T13:39:38.753Z | Command[79] status: addNode, status: ADD_NODE_STATUS_LEARN_READY |
| 2020-03-19T13:39:44.123Z | Command[79] status: addNode, status: ADD_NODE_STATUS_NODE_FOUND |
| 2020-03-19T13:39:48.742Z | Command[79] status: addNode, status: ADD_NODE_STATUS_FAILED |
| 2020-03-19T13:39:48.743Z | ProcessAddNode[58]: Error: ADD_NODE_STATUS_FAILED |
| 2020-03-19T13:39:48.747Z | Command[79] end: addNode |
| 2020-03-19T13:39:50.343Z | Command[80] start: addNodeAbort |
| 2020-03-19T13:39:50.344Z | Command[80] end: addNodeAbort |
Anyone else has the same problem? Home is like 1 meter away from the switch.
