Need Help With Homey Pro vs Philips Hue Previous Settings
Hi I am looking at creating a flow or an advanced flow, for when I am coming down our road of using the Apple CarPlay Homey Widget to open our electric garage door via a Flow. Then when the Ring External Contact Sensor mounted to the Electric Garage Door is triggered the Philips Hue Lights in the top Soffit turn green, confirming that the Electric Garage Door is open. I have done this by an existing flow and then turns off after two minutes.
But now that the darker nights are coming in, I’m looking that if it is night and the Soffit lights are already on the “Bright” scene and when the Garage Door is opened, they can still go green for two minutes to confirm to me that the door as opened as I am coming down the road approaching the house and then return back to their previous setting of “Bright”.
But now after two minutes if they can return to their previous state ie “off” in daylight, or “Bright” if on at night, or “off” again if it is past 11pm.
I have downloaded the “Zone Memory” app. But can’t really fathom this. Would appreciate some help if it is possible to do the above please?
Many thanks
When i understand you correctly, this is something you can do with the app Zone Memory.
The app can take a “picture” of the situation before the lamps go to green and after the 2 minutes the “picture” is used to set the situation as before.
Thanks for this Wilfred.
That sounds exactly that I am looking for. Under the Flow or advanced flow, what do I need to put in the Memory App? As it has loads of options for saving and recalling the scene.
When: Ring contact sensor; contact is on or off (i don’t know how it is used)
Then: Save state of (device) as (Name under which to store the dataset) [app memory zone]
After 2 seconds start hue scene turn lights green
After 122 seconds restore state of a device as (Name of the stored dataset) [app memory zone]
Something like this? You use in the then 3 cards:
first card from zone memory to save the state of the lights
Second card: After 2 seconds (to give homey the time to save the state) start the hue scene with green lights
Third card: After 122 seconds (so you have 120 seconds green lights) card from zone memory to restore the state of the lights
Afternoon Wilfred
Many thanks for your example. Have tried doing this, but under the Restore (final part), when I put the same name as the “Name of the stored dataset” it is not saving it. Just wondering if I have to save the Stored Dataset as a variable name?
When the Contact Alarm is turned on, the Garage Door has been opened.
A variable name isn’t necessary.
I use these 2 cards: the first to store the state
and the second one to “copy” the state back:
I hope this helps?!
Thanks Wilfred for the above screenshots. These were a massive help to me. Also I think that I have cracked the issue. Under the “Restore” card, it could not find the saved name as it didn’t exist. But when I tested the Save card, it then created the saved state, so now I can put the name in the “Restored” card and it pulls up the saved name from the Saved card.
Will hopefully try this tonight and hope it works. If it does, thank you so much for your help!
Peter
