"dim": {
"capability": "dim",
"stateTopic": "itho/state",
"setTopic": "itho/cmd",
"valueTemplate": "round((value / 255) * 100)",
"outputTemplate": "round((value / 100) * 255)",
"displayName": "Dim level"
"measure_temperature": {
"capability": "measure_temperature",
"stateTopic": "itho/ithostatus",
"setTopic": "",
"valueTemplate": "$.temp",
"outputTemplate": "",
"displayName": "Temperature"
"measure_humidity": {
"capability": "measure_humidity",
"setTopic": "",
"valueTemplate": "$.hum",
"displayName": "Humidity"
"measure_co2": {
"capability": "measure_co2",
"setTopic": "",
"valueTemplate": "$['CO2level (ppm)']",
"displayName": "CO2"
I think there is no CO2 sensor installed in the Itho.
Only the Temp en Hum sensor is available. Did you install an extra add-on in the Itho for Co2?
no I have not added an add-on, but via the ip address of the wifi addon I do see a co2 (ppmw) see photo previous post.
The remote also has an auto function that I think extracts on co2, I thought…
I know what you mean because I use the same module for my Itho.
If you have a Temp/Hum sensor installed on the module then there is no space to add an CO2 sensor.
The developer is working on a new sensor that includes CO2 but I think that will take some more time.
In the mean time I have a separate Air Quality meter installed.
