I’ve got my flow working with the help of this forum. Nevertheless… I don’t really understand what I’m doing. I’ve made a flow myself, which should work in my opinion but it doesn’t. The lights go on and off in a random manner, so it seems. Below I post a screenshot of the non-working flow. Can anybody tell me what I’m doing wrong? I’m trying to understand the basic “flows philosophy” to make more flows than just this one.
The link you send is exactly what I’ve done. It’s working. Nonetheless, I don’t understand why my previous flow isn’t working. You’re saying that I put the lights off in the “then” line, but the previous card says; dim the switch to 70 % with a duration of 5 seconds. (I’ve put in 5 seconds to test, but what it should be is somewhat like 600 seconds). What I expect is to set the lights to 70 % brightness for 5 seconds (or whatever time period) and then go out. I don’t want to reinvent the wheel, and don’t want to bother everybody on the forum every time I want to make a flow…
What you flow says at the then part is three starting 3 things at the same time, go lamp go on for 5 seconds at 70% dim, but at the exact same time , go off and at the exact same time start a flow. So you have to put some delations for the other then cards, card two in this case a delay off 5 seconds and the third card also a delay. Delays are countable. So second card delay 5 seconds and third card a delay off 10 seconds means that the third card starts 5 seconds after the second card.
Btw, ur first card sets the dim level over time starting from present dim level.
So if lights are on at 50%, the card goes from 50% to 70% over 5 seconds. Like it takes 5 seconds to go from 50 to 70%.
This is not a card to put the lights on for 5 seconds!
Thanks for the reply. I thought the “then” part was displayed in a chronological order, but apparently not. Thanks for the input.
Follow-up question: Is there a way to program the dimmer in a manner that it will overrule the sensor for a certain amount of time. To be clear; I’ve got an ecodimmer (zigbee/z-wave) controlling the lights that are also controlled by the new flow. I still would like to keep a certain amount of manual control capability. If I would like the lights of by pressing the dimmer, or maybe less or more brightness, the flow will overrule and put the lights back according to the flow.
